We have a kenmore elite quiet pak 4 HE 3T washing machine model 110.45976400. The issue is we keep getting a F11 fault code and not sure why. This code from what I am hearing is a wire harness coming loose. The code does come up only during a spin cycle. Where would I begin to look to tighten up the harness and which one(s)? I have not worked on washing machines before and I am not really a "handy man" type. I am willing to try and ready to start. Does any one have any input? Thanks in advance for your help. Jose' dominguez :)
You have said that you work in a washing machine before so I think you know the problem of your washing machine. But maybe I thin it is better if you call someone for a service. Good luck! online
Not sure who you are but you obviously didn't read the whole thing. I HAVE NOT worked on washing machines. Thanks for your two cents anyway and learn how to finish spelling your words. Originally Posted by: jossiegas5  You have said that you work in a washing machine before so I think you know the problem of your washing machine. But maybe I thin it is better if you call someone for a service. Good luck!
