avberviller
#1 Posted : Monday, March 3, 2008 1:31:57 PM(UTC)
avberviller
Burner didn't light; purchased igniter kit (MAC 1240035) and Valve.Safety (24" LP) (MAC 12002128). Burner still won't light. What's my next step? Salesman at AppliancePartsPro.com advised me to contact you. Thanks, AV Berviller
roycreamer
#2 Posted : Monday, March 3, 2008 2:45:25 PM(UTC)
roycreamer
Groups: Expert
if you are not getting power to those, which it sounds like you aren't, it could be your control/thermostat??? i don't know which one you have... but that's probably your problem...could be a fuse though... need model...
avberviller
#3 Posted : Tuesday, March 4, 2008 1:13:05 PM(UTC)
avberviller
Roy: I have a 24" Magic Chef built in oven, Model # 9122VUV, Serial # 13169386QY
I hope you can figure out what I need to do, I am frustrated and need some sweets fast! Thanks, Art
#4 Posted : Wednesday, March 5, 2008 9:46:32 AM(UTC)
Open the control panel, remove wires from the oven thermostat and check for continuity across the thermostat terminals while the thermostat is "on".
Replace the oven thermostat if it's open.
- The part number for the oven thermostat is AP379270
Here are the break down diagrams for the Magic Chef oven Model 9122VUV
avberviller
#5 Posted : Wednesday, March 5, 2008 1:30:20 PM(UTC)
avberviller
Gene: I just took off the panel and checked the thermostat per your instructions. There is continuity across it. What's next? Thanks, Art
#6 Posted : Wednesday, March 5, 2008 4:07:44 PM(UTC)
Hi Art,
If the new igniter glows but gas does not come out - check the gas shut off valve next to the gas safety valve. It could be closed since you replaced the safety valve.
If the igniter does not glow - check for 120V coming to the igniter while the thermostat calls for heat.
Post your findings, please.
rene
#7 Posted : Tuesday, July 1, 2008 8:29:58 PM(UTC)
rene
model 9122vuv sr 14055392sk the ignighter comes on, i press the safety valve and can smell gas but, oven doesn't light. what else can I check?
#8 Posted : Wednesday, July 2, 2008 11:09:36 AM(UTC)
rene,
Most likely the problem is a bad igniter even if it does glow. You can learn how oven igniter works from one of our previous posts:
http://forum.appliancepartspros...1897-oven-wont-lite.html
- The part number for the oven igniter is AP205873
Here are the break down diagrams for the Magic Chef range Model 9122VUV
Eddie365
#9 Posted : Friday, December 5, 2008 2:18:22 PM(UTC)
Eddie365
Hi. If ignitor comes on and you smell gas coming out, make sure the ignitor is line up with the gas tube because if you put it backwards is going to do just that, Ignitor will turn on you can smell gas but the flame
won't go on. and make sure you got the right ignitor and amps on ignitor match your manufacture model.
