arcbiscuit
#1 Posted : Friday, August 20, 2010 6:26:04 AM(UTC)
arcbiscuit
My washer will not fill with water, I have replaced water inlet valve , the water IS turned on. Without water in the bowl it spins and ejects the water just fine. When I fill the bowl with water say …1/3 of the way up and select “low” it agitates and works just fine , when I adjust the selector to medium or high it will not fill or agitate. I have cleaned out the tube leading to the water level switch and when I blow into the water level switch it starts agitating with or without water in the bowl , but it still will not fill with water.
The timer seems to be working…it “ticks” and advances as it always has.
sidfink43
#2 Posted : Sunday, August 22, 2010 11:00:30 AM(UTC)
sidfink43
Everything you report says that the water level switch is bad. Replace and see if that does not fix your problem.
arcbiscuit
#3 Posted : Monday, August 23, 2010 5:54:06 AM(UTC)
arcbiscuit
actally found the problem Sunday, was that stupid fuse located just under the the water level switch behind the front panel ... thanks for the help
sidfink43
#4 Posted : Monday, August 23, 2010 6:30:15 AM(UTC)
sidfink43
Great, glad you found the problem and thanks for the update
Guest (4)
