emilhogen
#1 Posted : Monday, June 30, 2008 2:34:05 PM(UTC)
emilhogen
I need to replace the Blower wheel assembly Part Number: AP3992539 made by MAYTAG, a part of the Motor Drive.
When the dryer spins, it makes a tumble noise. I opened the front panel and the noise comes from the Motor Drive. If I turn the dryer’s drum, it makes the noise with every revolution of the drum, but does NOT come from the drum rollers or the belt.
1. Does it sound like the blower wheel assembly needs to be replaced?
2. Can you provide a service manual or removal and assembly instructions?
#2 Posted : Tuesday, July 1, 2008 2:08:38 AM(UTC)
They should have info at the web site www.applianceaid.com Remove front panel and blower housing cover, then remove "C" clip and clamp from the motor shaft.
Maytag Dryer Repair (Dryer Repair)
by debmur 3/8/2012 11:53:39 AM(UTC)
Maytag Dryer repair - controller/timer (Dryer Repair)
by Brownibe 4/25/2010 10:22:57 AM(UTC)
2nd Request Maytag Dryer Repair (Dryer Repair)
by BIG COUNTRY 8/20/2009 10:15:26 AM(UTC)
Maytag Dryer Repairs made easy (Dryer Repair)
by heaterproblemeasy 7/10/2009 5:46:11 PM(UTC)
Maytag Dryer Repair Code F43 (Dryer Repair)
by GKHARMON 1/12/2009 1:00:48 PM(UTC)
Maytag Dryer Repair Question (Dryer Repair)
by deeboi74 7/13/2008 1:48:54 PM(UTC)
