nisky
#1 Posted : Monday, June 30, 2008 9:05:25 AM(UTC)
nisky
Will it be likely that, when replacing the transmission in this GE washer, I should need a new tub bearing, coupling, air bell screw and hub nut? Or, will just the xmission do the job?
abadfish66
#2 Posted : Monday, June 30, 2008 9:21:43 AM(UTC)
abadfish66
You need the tranny, tub seal, and hub nut, that will do. The only reason you would need to replace the coupling is if it is stripped.
Frigidaire Gallery transmission replacement (Washer Repair)
by ddavis263 2/27/2012 12:48:25 PM(UTC)
Maytag LA712 Transmission Replacement (Washer Repair)
by geebekazoo 6/27/2011 1:09:30 PM(UTC)
Maytag transmission replacement (clothes washer) (Washer Repair)
by gabaugher 3/31/2011 10:43:52 AM(UTC)
GE WJSR1070A Washer transmission replacement (Washer Repair)
by blueprintblue 12/9/2010 1:59:28 PM(UTC)
Maytag washer transmission replacement (Washer Repair)
by Billwhite 1/29/2008 7:10:14 AM(UTC)
