vgvidals
#1 Posted : Monday, August 16, 2010 2:42:55 PM(UTC)
vgvidals
whirlpool Refrigirator Model Number Gd5lhgxlq01. My Ice Maker Produces Ice With No Problem, But It Is Not Despencing Whole Or Crushed Ice Cubes. The Water Despencer And Light Work With No Problems. What Do I Need To Do To Fix The Ice Dispencer, What Parts Do I Need To Buy. Thank You For Yor Help
#2 Posted : Monday, August 16, 2010 3:57:16 PM(UTC)
What happens when you push the ice release lever?
Does it make any noise?
vgvidals
#3 Posted : Monday, August 16, 2010 4:10:17 PM(UTC)
vgvidals
no it does not make any noise, there is no movement of the auger all that works is the ice maker, that produces ice with no problem.
#4 Posted : Tuesday, August 17, 2010 2:00:39 PM(UTC)
Remove the dispenser front panel and check the micro switch and the bracket (#14 & #15 on the diagram). The disassembly instructions are attached to the reply.
Here are the breakdown diagrams and Dispenser front replacement parts for WHIRLPOOL GD5LHGXLQ01 | AppliancePartsPros.com
File Attachment(s):
Ice and water dispenser.doc (435kb) downloaded 17 time(s).
Ice despenser not working (Refrigerator & Freezer Repair)
by blackhercules39 6/19/2012 1:17:22 PM(UTC)
by rwils3 2/22/2012 11:28:59 AM(UTC)
