My icemaker works just fine, but it does not dispense any ice out when I press the button for crushed or cube ice...nothing comes out. There is ice in the bucket, but it does not come out when I press the button. What is the problem? Please help.
Groups: APP Team
Hi.
When you push the lever does the ice door open? Do you hear any humming noise from the auger motor in the freezer?
Thank you. Post the results.
Simon.
Yes, I do hear a humming sound and I do hear the ice door open when I press the lever.
Groups: APP Team
Hi. Check if the auger motor turns by hand, it may be frozen. Just defrost it. If the problem still exists use a multimeter to check the run capacitor and if it's bad - replace it Part number: 65889-4
Ok, Thanks I will give it a try!
Groups: APP Team
Originally Posted by: Simon / APP Team  You are welcome.
Simon. What is the best way to defrost the part? I took a warm cloth and put it on the part and the ice shot a few cubes out when I touch the cube lever. But, after about 5 seconds the ice would not dispense again. So tell me what is the best way to defrost this part?
Groups: APP Team
Use the blow dryer or take the motor out for a few hours. There is also possibilities that you will have to get a new motor.
Thank you.
Simon.
Ok thank you, hopefully I will not have to get a new motor. I appreciate your help!
Groups: APP Team
Any time. Post the results.
Simon.
