#1 Posted : Saturday, June 28, 2008 4:13:00 PM(UTC)
The freezer drain is in the back of the freezer, far away from the defrost heater and every three months the drain freezes.
Anyone know if there is a fix for this, the drain works fine after defrosting, but the drain area has a lot of styrofoam around it that I am sure is water soaked.
abadfish66
#2 Posted : Saturday, June 28, 2008 5:18:48 PM(UTC)
abadfish66
Have you run hot water through the drain to flush out anything that may be caught in there?
#3 Posted : Sunday, June 29, 2008 2:56:30 AM(UTC)
Used a turkey baster and pumped a lot of hot water down the drain. The drain is like one foot past the defrost heater with a narrow metal trough going to it with styrofoam all around it.
