my icemaker is stuck in harvest mode. the extractor just keeps revolving, and water will not fill the tray. any ideas? thx rick
Originally Posted by: bloozfann  my icemaker is stuck in harvest mode. the extractor just keeps revolving, and water will not fill the tray. any ideas? thx rick Sorry but, I could not cross reference any technical information for you. The model number you supplied is incorrect according to the Sears web sight. Depending on the icemaker in your unit, I would have to think, you have a shorted mold thermostat or a damaged control module on the icemaker. We can better serve you, if you supply the model number off of the serial tag on the inside of the fresh food compartment. :( :confused:
:( :confused: Sorry about the wrong model number. The correct one is 51554101, Kenmore coldspot.
Originally Posted by: bloozfann  Sorry about the wrong model number. The correct one is 51554101, Kenmore coldspot. Sorry, But 51554101 is not a good model number,as well. ( looks more like a serial number). How old is this refrigerator ? Could you take a digital picture and attach it to your next reply, so we can varify everything with or through Sears. We'd appreciate it greatly. :) :) :)
ok, I guess I left off the first 3 numbers. Lets try 10651554101, kenmore coldspot. Its 9 yrs old give or take. manufactured in 2001.
Originally Posted by: bloozfann  ok, I guess I left off the first 3 numbers. Lets try 10651554101, kenmore coldspot. Its 9 yrs old give or take. manufactured in 2001. Bloozfann, Thanks for the model number, made things a lot easier. Did you notice any water or ice dripping from the ice maker? Running water or ice on the ice cube chute, or in the bin ? As I understand your complaint, the cube extractor arm continues to run(never stops) and no water is injected into the ice maker to make cubes. If all that is correct, you have a failed mold thermostat, and or control module or both. I would reccomend you replace the ice maker(complete), instead of attempting to repair or rebuild the assembly. Part number: AP3182733
OK, thanks so much. I just ordered a new unit from you. You guys saved me quite a bit of money and I appreciate the timely responses. Now my wife will get off my back! Rick
Originally Posted by: bloozfann  OK, thanks so much. I just ordered a new unit from you. You guys saved me quite a bit of money and I appreciate the timely responses. Now my wife will get off my back! Rick Rick, Happy to hear it. Hoping all goes well. Good luck. :) :) :)
How do you remove the unit?
