jrallo3789
#1 Posted : Thursday, August 12, 2010 6:48:35 PM(UTC)
jrallo3789
Hello, Ok I have replaced all sensor's and igniter. Here what happens if the dryer sit's off for a day and then turn it on the igniter glows and the flame lites it stays on for a few minutes and then shuts off ( no flame) and the flame will not come on again for a day. I have spent 136.00 and still not working. I have check the exhaust and it is not clog I have a good exhaust coming out the vent. The only thing I have not replaced is the Regulator and the coils. Please help. Thanks.
kayakcrzy
#2 Posted : Sunday, August 15, 2010 5:25:53 AM(UTC)
kayakcrzy
Replace the coils on the gas valve. That should do it. Every once in awhile, the valve is bad. Tom ApplianceEducator.com
jrallo3789
#3 Posted : Monday, August 16, 2010 4:34:47 PM(UTC)
jrallo3789
Hello Tom,
Thanks for the info. Do I have to shut the gas off before replacing the Gas valves? My reg does not have a shut off valve on it. I must shut off my hot water heater as its also feed the dryer. But I really don't want to do that as the hot water tank bills up condenstions and when I go to lite it , it blow back into my face. THANKS JEROME.
kayakcrzy
#4 Posted : Tuesday, August 17, 2010 4:08:35 AM(UTC)
kayakcrzy
Hello Tom,
If you are just replaceing the 2 coils on the gas valve, you do not have to shut off the gas. If you were to replace the whole gas valve, you would. Tom ApplianceEducator.com
jrallo3789
#5 Posted : Sunday, August 29, 2010 6:21:43 AM(UTC)
jrallo3789
Hello Tom,
That did the trick. It works fine now. Too bad I bought those other parts and that wasn't the problem. The gas valves did it. I'm happy now. Thanks again.
Jerry
kayakcrzy
#6 Posted : Sunday, August 29, 2010 2:12:28 PM(UTC)
kayakcrzy
Good Job!!!!
