maddog627
#1 Posted : Friday, June 12, 2009 7:52:55 PM(UTC)
maddog627
How in the heck do you remove the timer from the control panel?:eek:
sidfink43
#2 Posted : Saturday, June 13, 2009 4:56:15 PM(UTC)
sidfink43
I assume you have opened the console by removing the two screws at the outer end of it and flipping it up. Your timer knob should come off by pushing it in and turning counterclockwise. This will expose the screws that hold it on.
Good luck, let us know if this does not do it.
tuggernuts
#3 Posted : Thursday, August 12, 2010 11:23:32 AM(UTC)
tuggernuts
I've got the front panel off the washer and the knob off the front and I still can't figure out how to take the timing unit off to replace it. I know it's gotta be something totally obvious I'm missing - please help.
sidfink43
#4 Posted : Thursday, August 12, 2010 3:12:44 PM(UTC)
sidfink43
Without a brand and model number we have no idea.
Post your info and let's see what you got.
tuggernuts
#5 Posted : Thursday, August 12, 2010 6:22:54 PM(UTC)
tuggernuts
It's a Maytag Dependable Care heavy duty washer model #LAT8704AAE
ThatGuy
#6 Posted : Thursday, August 12, 2010 8:40:37 PM(UTC)
ThatGuy
Groups: Expert
United States
The center part of the timer knob is a "plug" just take the tip of a small screwdriver and pop it straight out. Underneath is a clip. Slide it off the shaft. The knob is spring loaded, don't loose the spring. Pull the pointer straight up and off. Underneath are some screws.
See this diagram. Control panel replacement parts for MAYTAG LAT8704AAE Washer - Top Loading | AppliancePartsPros.com
need to replace timer on right side of panel (Washer Repair)
by Collis Dahle 8/7/2013 1:22:55 PM(UTC)
How Do I Replace Timer For Early Maytag Washer? (Washer Repair)
by jojomagic 2/20/2012 8:26:08 AM(UTC)
How to remove control panel to replace timer? (Washer Repair)
by schecter5 5/30/2011 11:30:16 AM(UTC)
How do I replace timer knob (Washer Repair)
by Doug2010 3/14/2010 3:34:21 PM(UTC)
Replace Timer? (Dishwasher Repair)
by nofearengineer 11/27/2009 6:50:46 AM(UTC)
replace timer (Dryer Repair)
by sharon lardarello 8/11/2009 6:38:46 AM(UTC)
need instructions to replace timer 8541275 (Washer Repair)
by pjkasle 6/9/2009 5:31:27 AM(UTC)
Maytag A612 How to replace timer? (Washer Repair)
by scuba1954 5/16/2009 11:01:39 AM(UTC)
Instruction to replace timer (Oven Repair (including Ranges and Cooktops))
by bert brewer 3/18/2009 10:11:41 AM(UTC)
replace timer (Washer Repair)
by dicesare 1/20/2009 5:35:57 AM(UTC)
How to replace timer (Washer Repair)
by jmeister 1/9/2008 8:58:14 AM(UTC)
How to replace timer control (Dishwasher Repair)
by wareagle 12/11/2007 8:13:28 AM(UTC)
