JClarke
#1 Posted : Thursday, August 12, 2010 5:38:02 AM(UTC)
JClarke
The washer stopped in the middle of a cycle. No codes were flashed and the control panel would allow selections but no response from the washer. I inititailly checked the continuity in the grey ribbon cable and it checked out OK. I have also checked the continuity in the wiring hrnesses from the door lock switch to the ECU. I have replaced the ECU and the electronic control panel and no change. I am down to either the motor control unit or the door switch. ANy ideas out there?
JClarke
#2 Posted : Friday, August 13, 2010 7:42:42 AM(UTC)
JClarke
Update: I wanted to add that when I started troubleshooting, the control panel would not turn on. This is why I replaced the ECU and Control panel first. I found a posting containing the factory technician repair manual on another repair forum site. I was able to get the resistence values for the various harnesses and components. The repair problem was an open in the door lock switch. I was able to jump the door lock switch and get the machine running through a cycle. The new switch should arrive today. :)
