Roslynk
#1 Posted : Friday, August 13, 2010 7:39:19 AM(UTC)
Roslynk
Dishwasher has a loud grinding noise and it seems to be getting no water. What part do I need to order?
Joe / APP Team
#2 Posted : Friday, August 13, 2010 8:27:55 AM(UTC)
Joe / APP Team
First, make sure the water supply to the dishwasher has not been turned off.
(the valve is usually under the kitchen sink).
If that is not the problem, with no water(fill) and a buzzing noise, my first impression would be that the water inlet valve is clogged or has failed.
Part number: AP3131916
Joe / APP Team
#3 Posted : Friday, August 13, 2010 8:36:31 AM(UTC)
Joe / APP Team
The first thing to do is, check and make sure the water supply was not turned off.
My first impression is, you probably have a clogged or failed water inlet valve
(buzzing noise and no water fill in the tub).
The valve is located behind the kickplate and lower access panel, on the left hand side of the dishwasher frame.
(click on number for parts information)
Part number: AP4113483
Guest (5)
Jenn-Air dishwasher, control panel or board? (Dishwasher Repair)
by stlb5 10/19/2015 8:18:17 AM(UTC)
Jenn-Air Dishwasher Runs When Door is Open (Dishwasher Repair)
by Rob F 8/2/2015 8:12:24 AM(UTC)
jenn-air dishwasher failure (Dishwasher Repair)
by hecdav1 3/8/2011 12:07:35 PM(UTC)
Jenn-Air Dishwasher stuck during cycle (Dishwasher Repair)
by octus 12/14/2010 10:04:25 AM(UTC)
Jenn-Air Dishwasher runs but lights don't work (Dishwasher Repair)
by lstubbers 1/27/2010 6:07:25 AM(UTC)
Jenn-Air Dishwasher Control Panel (Dishwasher Repair)
by paulcoovert 12/8/2009 3:15:38 PM(UTC)
Jenn-Air Dishwasher (Dishwasher Repair)
by dpell77@gmail.com 2/18/2009 11:35:49 AM(UTC)
Jenn-Air dishwasher (Dishwasher Repair)
by BDL 12/31/2008 4:59:37 AM(UTC)
Jenn-air dishwasher makes grinding noises (Dishwasher Repair)
by waynedeg 2/1/2008 1:58:19 PM(UTC)
Jenn-Air dishwasher won't run (Dishwasher Repair)
by bwcw12266 1/24/2008 5:50:01 PM(UTC)
