MSSugerman
#1 Posted : Thursday, August 12, 2010 7:46:03 AM(UTC)
MSSugerman
Washer cycle selection control knobs consist of a skirt & a knob. I just got the machine used. Does the skirt that allows you to select the washer cycle and the knob that controls on/off rotated together as if they were one or are they totally seperate?
ThatGuy
#2 Posted : Thursday, August 12, 2010 8:56:04 PM(UTC)
ThatGuy
Groups: Expert
United States
This should answer your questions.
Control panel replacement parts for MAYTAG PAV5158AWW Washer - Top Loading | AppliancePartsPros.com
MSSugerman
#3 Posted : Friday, August 13, 2010 7:07:45 AM(UTC)
MSSugerman
I was already aware that you have the knob & plate but my question is how the two parts are supposed to function. When you turn the knob, is that supposed to rotate the plate to the function you are selecting? As it stands now, you rotate the plate but it's smooth and has no easy way of grasping. If you turn the knob only (pushed in or not) it does not rotate to any selections. Are the knob & plate supposed to interact when rotated?
GE Glasstop stove burner control knob (Oven Repair (including Ranges and Cooktops))
by Guest 9/17/2023 5:25:35 AM(UTC)
Where can I find a control knob to fit a 5mm D shaft potentiometer? (Dryer Repair)
by Guest 6/29/2022 11:20:48 AM(UTC)
Kenmore 970-C80032-00 dryer Control Knob (Dryer Repair)
by Guest 5/30/2022 8:16:19 AM(UTC)
change dacor oven from touch pad to manual control knobs (Oven Repair (including Ranges and Cooktops))
by prop 1/15/2019 11:04:14 AM(UTC)
how to remove washer control knob (Washer Repair)
by Mrs.fixit 7/30/2015 11:43:56 AM(UTC)
Control knob (Washer Repair)
by glendot 5/24/2015 3:07:55 PM(UTC)
Dryer Control Knob Shaft (Dryer Repair)
by eogrady 12/28/2014 7:17:05 AM(UTC)
Range control knob broken (Oven Repair (including Ranges and Cooktops))
by boonjh 1/25/2014 3:16:45 PM(UTC)
Kitchenaid gas range power burner control knob doesn't turn past Lite (Oven Repair (including Ranges and Cooktops))
by dathinker 9/9/2013 9:31:18 AM(UTC)
Control Knob broke off during a move (Washer Repair)
by mattndi1991 8/4/2013 4:14:06 AM(UTC)
removing control knob on washer (Washer Repair)
by Jme1408 7/27/2013 8:51:53 PM(UTC)
Need Control Knobs (Oven Repair (including Ranges and Cooktops))
by ninaszlosberg 6/17/2013 4:13:45 PM(UTC)
Jenn-Air 5 burner control knobs are sparking (Oven Repair (including Ranges and Cooktops))
by HHStang 3/10/2013 6:55:34 PM(UTC)
Burner Control Knob (Oven Repair (including Ranges and Cooktops))
by Kdog12 7/17/2012 3:19:40 PM(UTC)
by kmenmart 7/16/2012 4:46:31 PM(UTC)
