lfd39
#1 Posted : Wednesday, September 12, 2007 9:34:19 AM(UTC)
lfd39
I have a gas stove and the oven has been getting slower to light to the point that i wait up to 30 minutes. I repalced the valve thinking that it was sticking with no possitive results. Is there a safety sensor or a poor power issue that could cause the valve to opening to be delayed????
ifishy
#2 Posted : Wednesday, September 12, 2007 3:21:47 PM(UTC)
ifishy
i have the same problem with my amana stove now it will no longer light i am in the process of tracking down the valve they no longer make the part. Is there something elese i should look at as well instead of just the valve
#3 Posted : Wednesday, September 12, 2007 8:42:04 PM(UTC)
Hi lfd39
Most likely the problem with your oven is a bad igniter. In order to help you better I need the complete model number of the oven. The model number you posted is incorrect.
#4 Posted : Wednesday, September 12, 2007 8:42:47 PM(UTC)
Hi ifishy
Model number ?????
lfd39
#5 Posted : Saturday, September 15, 2007 12:48:04 PM(UTC)
lfd39
Hi I read some other threads and decided to purchase an ignighter as suggested it came in yesterday I put it in and the oven is fine the old one glowed brighter than the new one but the new one works
#6 Posted : Saturday, September 15, 2007 7:32:19 PM(UTC)
Good job!
Williams123
#7 Posted : Tuesday, July 29, 2008 5:33:53 AM(UTC)
Williams123
Will the universal igniter such as Stove/Oven/Range Universal Flat-Style Ignitor - 12400035 work on the Viking? The oven was slow to light and now doesn't light...although both igniters glow red hot. Amp draw is 2.75 per unit when excited.
Overall length of igniter is 4-1/2 inches but the ceramic extends out the back of the bracket. From the end of the igniter to the center of the first mounting screw hole is 2-3/16".
Occassionaly the oven will light if I tap the gas valve.
#8 Posted : Tuesday, July 29, 2008 3:19:02 PM(UTC)
Williams123,
Both igniters are bad, no doubt about it.
You can use any kind of flat igniters as a replacement. The length of the ceramic can be shorter than on the original. The Maytag universal igniter 12400035 (APP item number AP205873) is a good choice.
Maytag oven slow to light, have replaced igniter and safety valve (Oven Repair (including Ranges and Cooktops))
by kellih 1/23/2013 4:30:54 PM(UTC)
Viking oven slow to light (Oven Repair (including Ranges and Cooktops))
by alaskachick 8/26/2012 10:54:59 AM(UTC)
Oven slow to light (Oven Repair (including Ranges and Cooktops))
by moonman 11/11/2008 5:53:52 AM(UTC)
