the water supply line to the ice maker keeps freezing up.
[FONT='Times New Roman'] Typically a bad water valve causes this but low water pressure can also cause this. Check the water pressure at the water dispenser and if it is low you may have to replace the water filter and if not replace the water valve. [/FONT] [FONT='Times New Roman'] [/FONT] [FONT='Times New Roman'] Refrigerator repair guide[/FONT] [FONT='Times New Roman'] [/FONT] [FONT='Times New Roman'] [/FONT]
