dennisjmay
#1 Posted : Tuesday, June 24, 2008 4:29:53 PM(UTC)
dennisjmay
A tech said I needed to replace the control board inside the console, only problem is I can't seem to open the console. Can you explain how to open the console?
#2 Posted : Wednesday, June 25, 2008 3:39:56 AM(UTC)
Tilt the dryer forward and remove the control back panel.
kayakcrzy
#3 Posted : Thursday, June 26, 2008 4:29:54 AM(UTC)
kayakcrzy
Before you replace a control board you might not need, check the thermal fuse on the blower housing. Take the bottom front panel off, and of course unplug the dryer, and stick your head in on the right side, and look hard left, sitting on the blower housing you will see the thermal fuse, it is the white part, round, with 2 wires going to it. If you want, take the 2 wires off, and put the ends together, and put some tape around them, so they don't hit metal, plug the dryer in, and see if it works. If so, DO NOT run the dryer without that part. It is the only thing between you, and burning down the house. If you need me you can reach me at my web site at ApplianceEducator.com
Kenmore Elite dryer won't start (Dryer Repair)
by Guest 6/22/2024 6:34:42 AM(UTC)
LG DLEX5170V electric dryer won't start (Dryer Repair)
by Guest 2/23/2024 11:17:20 AM(UTC)
Dryer won't start after changing fuses and timer (Dryer Repair)
by Guest 1/17/2023 11:21:44 AM(UTC)
Dryer Won't start - Repair Video (Dryer Repair)
by Guest 8/8/2021 1:55:18 PM(UTC)
Kenmore 100 Series Dryer Won't Start (Dryer Repair)
by juser 11/7/2020 4:44:16 PM(UTC)
Gas dryer won't start at all (Dryer Repair)
by GuyGreg 2/21/2018 2:26:33 PM(UTC)
Dryer won't start (Dryer Repair)
by Ginadrc 1/26/2018 7:24:30 PM(UTC)
by Petem 12/2/2017 3:27:50 PM(UTC)
Maytag dryer won't start (Dryer Repair)
by eagle243 11/15/2017 6:44:39 PM(UTC)
Dryer won't start after replacing the heating element (Dryer Repair)
by ivyholly 6/8/2017 6:45:42 PM(UTC)
Dryer Won't Start-Lights Blinking (Dryer Repair)
by rleigh 6/5/2017 9:20:31 AM(UTC)
Inglis dryer won't start (Dryer Repair)
by jkeefe 4/20/2017 2:48:09 AM(UTC)
Amana Dryer won't start, but still gets hot (Dryer Repair)
by halfmoonranch 3/15/2017 9:38:33 AM(UTC)
Dryer won't start (mid-troubleshooting, could use some help) (Dryer Repair)
by OUberLord 3/13/2017 7:15:55 PM(UTC)
Whirlpool Dryer Won't Start (Dryer Repair)
by agjr200hp 2/5/2017 5:36:21 AM(UTC)
