Natasha Beckford
#1 Posted : Wednesday, August 11, 2010 8:09:02 AM(UTC)
Natasha Beckford
My Admiral dishwasher will not drain so if anyone out there might have a solution I would be very grateful. :)
Joe / APP Team
#2 Posted : Wednesday, August 11, 2010 8:58:11 AM(UTC)
Joe / APP Team
We need, at least a model number for various research needs,
The model and serial tag should be located on the tub frame(opening),usually on the top or left side of the tub or door.
We can help better if you could get that for us.
:) :confused:
Natasha Beckford
#3 Posted : Thursday, August 12, 2010 7:30:56 AM(UTC)
Natasha Beckford
I looked for the model and serial number where you suggested but was unable to locate it. :( What next?
Joe / APP Team
#4 Posted : Thursday, August 12, 2010 8:29:36 AM(UTC)
Joe / APP Team
Unfortunately,
There's not much more we can do.
Admiral had 3 or 4 different versions of dishwashers ( depending on age),and even one that was produced in another country.
Here are a few general things to check :
Does the motor run in the drain cycle ?
Do you hear a click noise at the start of the drain cycle ?
If you have a grille in the back center of the bottom of the tub, check and make sure there is nothing clogged or blocking the grille,or the sump under the grille.
Check the drain hose and disposal connection for clog.
(disconnect the drain hose at the disposal/drain connection, and drain water into a bucket).
That's about as far as I can you for now.
Natasha Beckford
#5 Posted : Friday, August 13, 2010 5:23:13 AM(UTC)
Natasha Beckford
Thanks for all of your help.
Joe / APP Team
#6 Posted : Friday, August 13, 2010 5:40:26 AM(UTC)
Joe / APP Team
You're welcome :) .
Sorry, we couldn't do more for you :(
Whirlpool Dishwasher Won't Drain Completely, I hear Pump Running... (Dishwasher Repair)
by Guest 4/18/2022 5:39:50 PM(UTC)
Bosch SHU33 dishwasher won't drain when hot just after a wash (Dishwasher Repair)
by Guest 7/12/2021 7:43:33 AM(UTC)
Bosch dishwasher won't drain, begins cycle, then stops - FIXED (Dishwasher Repair)
by mabradbury 1/17/2019 7:08:25 PM(UTC)
Bosch dishwasher won't drain completely (Dishwasher Repair)
by nathaniel.hoffman@gmail.com 12/25/2018 6:30:47 AM(UTC)
GE dishwasher won't drain after last rinse cycle (Dishwasher Repair)
by autotech1 1/22/2018 9:47:40 AM(UTC)
Dishwasher won't drain (Dishwasher Repair)
by Drummabouy 6/22/2017 6:29:14 AM(UTC)
Dishwasher Won't Drain or Run Cleaning Cycle (Dishwasher Repair)
by Katie L 8/4/2016 2:07:24 PM(UTC)
Bosch Dishwasher won't drain and goes directly to "Clean" Light (Dishwasher Repair)
by ed3120 6/4/2016 4:40:01 AM(UTC)
by brokenge 2/18/2016 2:32:59 PM(UTC)
Frigidaire dishwasher won't drain (Dishwasher Repair)
by kohanz 12/4/2015 9:35:55 PM(UTC)
Dishwasher won't drain! (Dishwasher Repair)
by Crafter_Man 10/12/2015 4:30:35 AM(UTC)
GE Dishwasher won't drain all way (Dishwasher Repair)
by AnthonyJS02 1/10/2015 9:12:07 AM(UTC)
by av0612 8/6/2014 4:42:36 PM(UTC)
Frigidaire Gallery Series Dishwasher won't drain fully after disposal replacement (Dishwasher Repair)
by wicked94pgt 7/17/2014 7:31:44 PM(UTC)
GE Dishwasher won't drain (Dishwasher Repair)
by crabbygardener 6/10/2014 6:30:07 PM(UTC)
