John l smith
#1 Posted : Thursday, August 5, 2010 4:23:50 PM(UTC)
John l smith
I realize my Original questions submitted on 07-29-2010 05:26 PM
might take some research !
While I Waite for a response to my Questions Is it safe to continue using this Unit ?
The crack runs the entire length 36" but it still supports the pans OK !
Also this is a monogram which is very expensive so I would like to avoid replacing the whole unit !
Any advise will be greatly appreciated .
bayoa
#2 Posted : Wednesday, August 11, 2010 12:40:07 PM(UTC)
bayoa
You can still keep using the cooktop, as it can still hold the weight of ur cookware. But, you need to be very careful to avoid spills on the cracked ceran it may cause a thermal shock and shatter the cooktop completely
John l smith
#3 Posted : Wednesday, August 11, 2010 4:03:31 PM(UTC)
John l smith
OK this is good to know !
I am hoping somebody can come up with answers to my original questions sent in on 07-29-2010 05:26 PM
But its good to know I can still use it until I can get it fixed or replaced
Thank You
lesleywhitehouse
#4 Posted : Wednesday, August 11, 2010 4:13:44 PM(UTC)
lesleywhitehouse
I had a cracked cooktop also--everything worked OK. I ordered a new cook top only, was not too expensive and put it in myself. I continued to use the stove without problems until the new top arrived. Lesley
lesleywhitehouse
#5 Posted : Wednesday, August 11, 2010 4:15:39 PM(UTC)
lesleywhitehouse
Try turning off the breaker to the oven and that turns off my error message.
John l smith
#6 Posted : Friday, August 13, 2010 3:58:29 PM(UTC)
John l smith
I think I can change this top.
My cooktop has stainless trim!
I can order a new top with or without the trim ( the price is about $300 More with trim ) GE MONOGRAM ZGU36ksk2ss
So I want to know if I can get a new top without trim and transfer the old trim to it ???
Instructions would be nice Too !
bayoa
#7 Posted : Friday, August 13, 2010 4:53:50 PM(UTC)
bayoa
please use the link below it will help u locate ur model number. I can chk to see if the cooktop is sold seperately without the trims on it.
Model Number Locator
John l smith
#8 Posted : Friday, August 13, 2010 6:13:29 PM(UTC)
John l smith
