replaced heater harness defrost assembly, but freezer still icing up and refrig warm also there is a beeping noise comming from the freezer at the top by the defrost fan. What do I do?
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
Originally Posted by: Gene  Replaced both items, and the evaporator is covered with ice/snow. Tripped the defrost timer and heard a beeping sound from the freezer section.
replaced both items, evaporator is covered in snow/ice. tripped the defrost timer and heard a beeping sound in the freezer.
Originally Posted by: hotbox  ...evaporator is covered in snow/ice...
...heard a beeping sound in the freezer... How it is covered - 100% or less? Is it snow or ice? There is nothing in the freezer what can beep. May be that sound was kind of sizzling? Gene.
Gene. evaporator is covered in snow, 80%. Noise is the evaporator motor which is spinning slowly and has what appears to be rust around the bottom.
evaporator is covered with snow, 80
evaporator covered approx. 80
evaporator covered approx. 80% with snow. Also the noise is coming from the evaporator motor which is spinning slow to start and makes the beeping noise.
Quote:...Noise is the evaporator motor which is spinning slowly and has what appears to be rust around the bottom... Most likely this is the problem. The new motor should fix it. Unfortunately it is on the manufacturer back order. You can call the APP customer service to find out the ETA. - The evaporator fan motor Part number: AP2071868
Gene. P.S. Please don't duplicate yours replies. It does not do any good.
