hotbox
#1 Posted : Tuesday, August 10, 2010 11:43:17 AM(UTC)
hotbox
replaced heater harness defrost assembly, but freezer still icing up and refrig warm also there is a beeping noise comming from the freezer at the top by the defrost fan. What do I do?
hotbox
#2 Posted : Tuesday, August 10, 2010 11:45:14 AM(UTC)
hotbox
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
#3 Posted : Tuesday, August 10, 2010 5:19:53 PM(UTC)
Did you replace both defrost heaters and the thermostat?
How the evaporator is covered with ice and/or snow?
Here are the breakdown diagrams and Replacement parts for General Electric TPX24SIBBBS Refrigerator | AppliancePartsPros.com
hotbox
#4 Posted : Wednesday, August 11, 2010 7:16:50 AM(UTC)
hotbox
Replaced both items, and the evaporator is covered with ice/snow. Tripped the defrost timer and heard a beeping sound from the freezer section.
hotbox
#5 Posted : Wednesday, August 11, 2010 7:18:17 AM(UTC)
hotbox
replaced both items, evaporator is covered in snow/ice. tripped the defrost timer and heard a beeping sound in the freezer.
#6 Posted : Wednesday, August 11, 2010 12:19:00 PM(UTC)
Originally Posted by: hotbox Go to Quoted Post
...evaporator is covered in snow/ice...
...heard a beeping sound in the freezer...
How it is covered - 100% or less? Is it snow or ice?
There is nothing in the freezer what can beep. May be that sound was kind of sizzling?
hotbox
#7 Posted : Wednesday, August 11, 2010 1:23:15 PM(UTC)
hotbox
evaporator is covered in snow, 80%. Noise is the evaporator motor which is spinning slowly and has what appears to be rust around the bottom.
hotbox
#8 Posted : Wednesday, August 11, 2010 1:38:39 PM(UTC)
hotbox
evaporator is covered with snow, 80
evaporator covered approx. 80
evaporator covered approx. 80% with snow. Also the noise is coming from the evaporator motor which is spinning slow to start and makes the beeping noise.
#9 Posted : Wednesday, August 11, 2010 4:18:25 PM(UTC)
Quote:
...Noise is the evaporator motor which is spinning slowly and has what appears to be rust around the bottom...
Most likely this is the problem. The new motor should fix it. Unfortunately it is on the manufacturer back order. You can call the APP customer service to find out the ETA.
- The evaporator fan motor Part number: AP2071868
P.S. Please don't duplicate yours replies. It does not do any good.
Guest (4)
