kescrig
#1 Posted : Tuesday, August 10, 2010 10:42:33 AM(UTC)
kescrig
Like the title says. I locked the door cause I have a 2 year old and 2 days later it wont heat up. The broiler and stove top work fine, just no heat.
#2 Posted : Tuesday, August 10, 2010 3:45:51 PM(UTC)
I'm assuming the Bake is not working after you used the self clean. Is it right?
What is the complete model number of the range?
kescrig
#3 Posted : Tuesday, August 10, 2010 4:40:08 PM(UTC)
kescrig
Gene,
No never used the did not use the self cleaned, it was just locked for a couple days.
Model # FEFL64FSB
Everything else works fine on the oven/stovetop
#4 Posted : Tuesday, August 10, 2010 4:54:59 PM(UTC)
How did you lock the door?
Does it show any error codes on the display?
