Like the title says. I locked the door cause I have a 2 year old and 2 days later it wont heat up. The broiler and stove top work fine, just no heat.
I'm assuming the Bake is not working after you used the self clean. Is it right?
What is the complete model number of the range?
Gene, No never used the did not use the self cleaned, it was just locked for a couple days. Model # FEFL64FSB Everything else works fine on the oven/stovetop
How did you lock the door?
Does it show any error codes on the display?
