ssacrf
#1 Posted : Monday, June 2, 2008 6:13:24 PM(UTC)
ssacrf
This is a free-standing gas range/oven. The range burners all work, but today the oven won't do anything (bake or broil). I need some guidance to figure out where to start. Thermostat? Safety Valve? Igniter? :confused:
Any guidance will be greatly appreciated!!
abadfish66
#2 Posted : Tuesday, June 3, 2008 10:25:39 PM(UTC)
abadfish66
when you turn on the bake does the glow bar glow? same with the broil? let's start there
ssacrf
#3 Posted : Wednesday, June 4, 2008 5:39:41 PM(UTC)
ssacrf
No. Nothing happens. Turned to bake = nothing; Turned to broil = nothing. :(
ssacrf
#4 Posted : Friday, June 6, 2008 5:14:57 AM(UTC)
ssacrf
Just a little more info: this oven has only one igniter / glow bar; the bake and broil functions out of the same buner. In reading this and other forums, it seems that some GE's have two different igniter / glow bars.
Anyone have any suggestions? I just want to replace the broken item on this oven and it appears that the issue may be with one of three things: 1) Thermostat (could be, b/c it appears to be the switch that controls the oven/broiler operation and the ignitor is not doing anything)
2) Safety Valve (not likely from what I can figure)
3) Ignitor (most likely? as it simply does not glow or show any signs of life)
I guess it says something about our eating / cooking habits that we are able to be OK without our oven working --- :rolleyes:
abadfish66
#5 Posted : Friday, June 6, 2008 7:10:33 AM(UTC)
abadfish66
Take a ohms reading of the glowbar, the wire ends will be behind the bottom drawer at the safety valve, post results
ssacrf
#6 Posted : Monday, June 23, 2008 3:06:59 PM(UTC)
ssacrf
It took awhile, but I finally got an Ohms reading...it is zero. I assume that means that the igniter/glowbar is shot?
edit: the Ohm reading was actually "nothing" or infinity, not zero. :o
#7 Posted : Tuesday, June 24, 2008 1:50:45 PM(UTC)
Yes, you are right. The igniter is bad and has to be replaced.
- The part number for the oven igniter is AP2014008
ssacrf
#8 Posted : Tuesday, June 24, 2008 5:44:42 PM(UTC)
ssacrf
Guys, thanks for the help; ignitor is in and oven is working :D :)
#9 Posted : Tuesday, June 24, 2008 7:02:06 PM(UTC)
We're glad you were able to fix it.
ssacrf
#10 Posted : Friday, June 27, 2008 9:07:38 PM(UTC)
ssacrf
Guest (11)
