Water Keeps Dripping From The Ice Maker Fill Tube Once The Ice Bin Is Full And Then The Ice Maker Does Not Make Anymore Ice Without Thawing The Fill Tube. Is That A Bad water Inlet Valve? I also get a drip from the water dispenser to.
Sounds like your valve is bad, have you done anything recently? Changed waterfilters, installed reverse osmosis or anything that may have gotten air in your water?
Had a problem with the ice maker working, replaced the thermostat now it is working except for the dripping. removed the filter right now because I have new ones on order. re bled the lines.
