sunal4
#1 Posted : Sunday, August 8, 2010 5:18:26 PM(UTC)
sunal4
I have a GE Profile Performance Refrigerator where the Freezer has stopped cooling. I know the back coils are frozen, I've defrosted it once already, but it's only been a week and it froze again. I'm not exactly sure how to check if the defroster is working or where it is. Is there a diagram you can send me that shows where it's all located and how I go about testing it to see if it works? Or how to turn it on to defrost? I read I can stick a screwdriver in a hole and turn it till it clicks, where is this hole and should I unplug the fridge first? I'm not too experienced with this, but if I'm able to see it I can figure it out, and I can't afford to call someone to come and fix it. I've tried to look up the Model number, but it can't be found...please any advice would be wonderful.
#2 Posted : Monday, August 9, 2010 4:41:08 AM(UTC)
Here are your parts, I used the BA unit
Replacement parts for TRX22PPDA models | AppliancePartsPros.com
First remove the evaporator cover in the freezer so you can see the coils.
Do not let them de-ice.
If they are heavily iced/frosted over you have a defrost problem.
If yes.
Manually force a defrost cycle by turning the defrost timer cam (Item 257 in Section 4) till the fans and compressor turn off.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the timer needs replacing, re: it is probably stalling during it's rotation so is never getting into a defrost cycle.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element (Item 230 in Section 3) from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat (Item 240 in Section 3) and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost timer contacts are toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
sunal4
#3 Posted : Monday, August 9, 2010 6:33:12 AM(UTC)
sunal4
I turned the timer and the fan and compressor went off. The coils are heavily frosted with ice, I think I found the heater and it's not hot or warm. The middle heater is covered with ice and no wires are visible. The bottom heater is visible, but I can't seem to locate the wires, should I defrost it with a hair dryer?
Now since the heater is not working (or I assume), how do I measure the heating elements. Is the heating element the coils or the heater itself? What colored wire should I measure (FYI I'm a novice at this). Thanks!
#4 Posted : Monday, August 9, 2010 8:06:14 AM(UTC)
[COLOR="Blue"]The bottom heater is visible, but I can't seem to locate the wires, should I defrost it with a hair dryer?[/COLOR]
Yes, if it is that badly iced up you will have to defrost it just to get to the heater's wires.
[COLOR="Blue"]Now since the heater is not working (or I assume), how do I measure the heating elements. Is the heating element the coils or the heater itself?[/COLOR]
Heating element is the heater itself. The coils usually refer to the evaporator coils through which the freon runs.
The heater has a wire coming from each end just disconnect it and measure between the wires.
Be sure to have the fridge unplugged when you do this.
If it is OK, then check the defrost thermostat. Since the coils are defrosted you will have to hold the thermostat on an ice cube to check it.
[COLOR="Blue"]
What colored wire should I measure (FYI I'm a novice at this).[/COLOR]
I do not know but once the unit is defrosted it will become self evident.
sunal4
#5 Posted : Monday, August 9, 2010 11:31:59 AM(UTC)
sunal4
I defrosted all the ice. Now how do i use the meter? What wire do i remove from the heater itself; any or a specific one? How do i test it using the meter? What sort of reading am i suppose to get? Also a seperate questions about the meters, does the red wire go in the ohm and the black in the comm?
#6 Posted : Tuesday, August 10, 2010 2:31:18 AM(UTC)
[COLOR="Blue"]I defrosted all the ice. Now how do i use the meter? What wire do i remove from the heater itself; any or a specific one?[/COLOR]
I would remove both wires.
If your unit has the same heater as the BABS unit Item 230 in Section 4 unplug it and measure it. Note that it has the defrost thermostat built into the assembly so you will have to hold the face of the thermostat on an ice cube as it is only closed (0 ohms) when frozen.
[COLOR="Blue"]
How do i test it using the meter?[/COLOR]
[COLOR="Blue"]What sort of reading am i suppose to get?[/COLOR]
The heater is usually around 20 ohms and the defrost thermostat 0 ohms when frozen.
[COLOR="Blue"]Also a seperate questions about the meters, does the red wire go in the ohm and the black in the comm?[/COLOR]
Yes.
Then short the meter leads together to see what 0 ohms should look like.
GE Profile Performance Refrigerator (Refrigerator & Freezer Repair)
by patma 8/25/2010 10:54:49 AM(UTC)
