dharris034
#1 Posted : Sunday, August 8, 2010 9:41:27 AM(UTC)
dharris034
I can here the refrigerator working but the freezer is not getting cold and the refrigerator is barely staying cold. I checked both temp inside toe refrigerator to make sure they are on the correct numbers and they are. I shut them off and I can here the motor come on and off but its not keepint the freezer nor refrigerator at the temperature they should be at.
#2 Posted : Sunday, August 8, 2010 11:53:31 AM(UTC)
Remove the back cover and check the compressor; if it's running, it should vibrate and get the condenser tubing hot.
dharris034
#3 Posted : Sunday, August 8, 2010 12:01:13 PM(UTC)
dharris034
Yes the yes its vibrating and the condesner tubing iis hot.
#4 Posted : Sunday, August 8, 2010 12:35:39 PM(UTC)
You have refrigeration systems problems for a pro. to look at, probably a bad evaporator leak.
dharris034
#5 Posted : Sunday, August 8, 2010 2:01:59 PM(UTC)
dharris034
Is this an expensive fix were I should just purchase a new refrigerator?
#6 Posted : Sunday, August 8, 2010 4:30:51 PM(UTC)
Most people get it checked by a pro. some rare cases it's fixable, but still not cheap, $200- $600
dharris034
#7 Posted : Sunday, August 8, 2010 4:48:19 PM(UTC)
dharris034
Thanks I've scheduled an appt for tomorrow.
