mikecantin
#1 Posted : Monday, May 19, 2008 1:15:20 PM(UTC)
mikecantin
The chord on the left side of the dishwasher broke. The right side is OK
I found the parts on line, but I don't know how to install.The part is called
hindge pulley and cable assembly. One end attaches to the door,the other to the spring,at the rear. Basically, I can't see how to remove the original pulley assembly
Any help would be greatly appreciated. thanks.
mikecantin@comcast.net
#2 Posted : Tuesday, May 20, 2008 1:28:53 PM(UTC)
Hi Mike,
In order to replace the door hinge pull the dishwasher has to be removed from the cabinet. One end of the cable is attached to the door spring while the other end is attached to the hinge lever.
- The part number for the door hinge pull is AP3775662
Here are the break down diagrams for the Bosch dishwasher Model SHX56B05 UC/14 (FD 8211-)
Eric18
#3 Posted : Friday, August 6, 2010 9:17:34 PM(UTC)
Eric18
Hi Mike,
How do I get the old pulley off? Do you have to take the whole base off?
