The chord on the left side of the dishwasher broke. The right side is OK I found the parts on line, but I don't know how to install.The part is called hindge pulley and cable assembly. One end attaches to the door,the other to the spring,at the rear. Basically, I can't see how to remove the original pulley assembly Any help would be greatly appreciated. thanks. mikecantin@comcast.net
Hi Mike, In order to replace the door hinge pull the dishwasher has to be removed from the cabinet. One end of the cable is attached to the door spring while the other end is attached to the hinge lever. - The part number for the door hinge pull is AP3775662 Here are the break down diagrams for the Bosch dishwasher Model SHX56B05 UC/14 (FD 8211-)Gene.
Originally Posted by: Gene  Hi Mike, In order to replace the door hinge pull the dishwasher has to be removed from the cabinet. One end of the cable is attached to the door spring while the other end is attached to the hinge lever. - The part number for the door hinge pull is AP3775662 Here are the break down diagrams for the Bosch dishwasher Model SHX56B05 UC/14 (FD 8211-)Gene. How do I get the old pulley off? Do you have to take the whole base off?
