My dryer has no heat though it works otherwise. I think I have narrowed it down to the heating element being burned out. I have taken it completely apart but cannot remove the drum. There are no screws 6 inches from the floor on either side and there is no rear access panel. I have removed the belt from the pulleys and the yellow clip from the front. What am I missing? thanks Rory
reach inside the drum and hit it upward hard, the brum has a ball on it that sits in a socket, you need to get it up and out of the socket
I would check the thermal limiter and see if it is open, it's the small device on the top right hand side of the heater assembly if the heater is good
My dryer has no heat though it works otherwise. I think I have narrowed it down to the heating element being burned out. I have taken it completely apart but cannot remove the drum. There are no screws 6 inches from the floor on either side and there is no rear access panel. I have removed the belt from the pulleys and the yellow clip from the front. What am I missing? How do I remove the drum?
My dryer has no heat though it works otherwise. I think I have narrowed it down to the heating element being burned out. I have taken it completely apart but cannot remove the drum. There are no screws 6 inches from the floor on either side and there is no rear access panel. How do I remove the drum?:confused:
