Brian Mosdal
#1 Posted : Saturday, June 21, 2008 6:34:58 AM(UTC)
Brian Mosdal
I have a 2-1/2 year old GE Top refrigerator / bottom freezer. It was struggling to maintain the freezer temp, so I cleaned the little bit of dust off of the condensor coils. When I was doing this, I noticed that the condensor coil fan was not running. I replaced this, but it still isn't working. What should I be checking next?
Thanks,
Brian
abadfish66
#2 Posted : Saturday, June 21, 2008 8:27:00 AM(UTC)
abadfish66
Get me your serial#, the problem is you need a new control board, and if the serial# is within a certain range, GE will replace the board for free
Brian Mosdal
#3 Posted : Saturday, June 21, 2008 5:51:14 PM(UTC)
Brian Mosdal
My serial number is:
ZH042129
Please send me info. as to what to do.
Appreciate your help so far very much.
Thanks,
Brian Mosdal
abadfish66
#4 Posted : Monday, June 23, 2008 6:59:47 AM(UTC)
abadfish66
Call 1-800-ge-cares you refer falls within the range for bad boards, call and set up service.
abadfish66
#5 Posted : Monday, June 23, 2008 10:53:31 AM(UTC)
abadfish66
I take that back it is not a free repair, it does not fall within the serial range!!! Either way, you need a new board to correct your problem. Sorry for the wrong ealier post
Brian Mosdal
#6 Posted : Monday, June 23, 2008 6:03:20 PM(UTC)
Brian Mosdal
Thanks for the info! Appreciate your help.
Brian
keithdixon
#7 Posted : Tuesday, February 3, 2009 3:44:10 PM(UTC)
keithdixon
Can anyone tell me if my control board falls under GE's free replacement? Serial # AF240381
Thanks!
