petros
#1 Posted : 15 years ago
petros
Hello,
Before about a month I noticed that there was no water coming from the water dispenser. After a while I realized that the water was running to the floor.. I found that the water tube was cut just before water pump. As I read in your forum probably it has to do with a excessive temperature caused from a faulty fan or a faulty motherboard is that right?
Can you please tell me what should I check and what parts should I replace?
Thank you very much!
Petros
Joe / APP Team
#2 Posted : 15 years ago
Joe / APP Team
Originally Posted by: petros Go to Quoted Post
Hello,
Petros
As I understand this,
The water supply tube, going to the water inlet valve, from the water supply is broken or cracked, and leaking , is this correct .
If that is the case, it has nothing to do with a fan or motherboard.
How long have you had the refrigerator ?
Is there enough room around the refrigerator to allow for good / proper air circulation(at least 1/2 inch openning on both sides and top of the unit).
Have you checked and cleaned the condenser coil and compressor compartment ?
applianceman
#3 Posted : 15 years ago
applianceman
If the fan weren’t running the refrigerator wouldn’t be cooling because the compressor would overheat. I don't think this is your problem.
If the line was broken repair the line. If there is any heat covers on the line make sure they are in place.
But you can look at the fan to see if it is running or not (it should be running anytime the compressor is on) and if not you certainly need to get that fixed. If the fan isn’t running this page should help GE Refrigerator Fan Motor Diagnostics
petros
#4 Posted : 15 years ago
petros
The water supply tube, going to the water inlet valve, from the water supply is broken or cracked, and leaking , is this correct?
Hello,
Thanks for answer.
Yes the water supply tube has broken. I have the refrigerator for around 5 years.
Only from the right side it is less than 1/2 inch..
No I haven't checked and cleaned the condenser coil and compressor compartment.
Hello
First of all thank you for your reply.
When I realized the problem I also noticed an overheat of the refrigerator's back side, even was the floor..
I removed the broken part of the water tube and then I reconnected it.
After about a week the water tube broke again..
I fixed it but after about a month the tube broke again..
The fun is running but i think slower...
Joe / APP Team
#5 Posted : 15 years ago
Joe / APP Team
Hello,
Thanks for answer.
Hello
Ok then,
I still don't know if the broken water tube is going into the water valve or is going from the water valve to the icemaker or water dispenser.
If the tube is on the inside of the compressor compartment,it is going out to the component(s).
It could be just normal due to age and temps(normal) in the compressor compartment.
*Cleaning the coils and compartment of dust and debris will assist in proper air circulation and cooling of internal components.*
You may need to replace the water tube, if you've removed most of the slack, and the tube is still brittle, you should replace the tube.
As for the condenser fan motor running slow, it is a possibility, in older units a probability,if it appears to be running slow , it probably is,and should be replaced as well.
*You should review the web sight that Applianceman attached to his post for more information.
Hope this helps.:)
petros
#6 Posted : 15 years ago
petros
Ok then,
Hope this helps.:)
Hello Joe,
It is the tube from the water valve to the icemaker or water dispenser.. I have removed a part of the tube and now there is no enough tube to reconnect.. I don't know if it could be pulled out a bit more..
Probably I will have to replace the tube..
I will also check the fan diagnostics.
Thank you and the Applianceman for your help! ;)
Joe / APP Team
#7 Posted : 15 years ago
Joe / APP Team
Hello Joe,
You're quite welcome,
It's been a pleasure to help.
Fresh food door doesn't self close & water dispenser problems (Refrigerator & Freezer Repair)
by RWSR 13 years ago
Whirlpool Water Dispenser Problems (Refrigerator & Freezer Repair)
by platemaster 14 years ago
Water dispenser problem (Refrigerator & Freezer Repair)
by nirvana_1959 14 years ago
by LIKEIT 14 years ago
Water dispenser problems (Refrigerator & Freezer Repair)
by hivoltg35 16 years ago
Water Dispenser Problem (Refrigerator & Freezer Repair)
by fabspe 16 years ago
by mlonas 16 years ago
Kenmore icemaker and water dispenser problems (Refrigerator & Freezer Repair)
by jenlow 17 years ago
by Noose 17 years ago
Refrigerator water dispenser problems (Refrigerator & Freezer Repair)
by moransm 18 years ago
