travelanman0203
#1 Posted : Friday, June 20, 2008 5:16:45 AM(UTC)
travelanman0203
I just received a new timer installed it and it does the same thing as old timer it fills it agitates and stops
#2 Posted : Friday, June 20, 2008 4:44:33 PM(UTC)
Why did you decide to replace the timer?
Most common cause of such problem is a bad lid switch (#11 on the break down diagram). Bypass the lid switch and see if the washer will drain and spin.
- New lid switch and step by step instructions on how to replace the lid switch: Part number: AP3100003
Here are the break down diagrams for the Whirlpool washer Model LSQ8520JQ0
travelanman0203
#3 Posted : Friday, June 20, 2008 7:30:21 PM(UTC)
travelanman0203
hey Gene
thanks for the reply I replaced the timer because I figured that everything started with the timer I did not ask anyone first next time I will how do you by pass that switch? thanks:) :)
will not cycle past wash (Washer Repair)
by travelanman0203 6/20/2008 5:21:03 AM(UTC)
