twbrans
#1 Posted : Tuesday, August 3, 2010 2:15:22 PM(UTC)
twbrans
I have one of the infamous front loading Kenmores with the spider arm assembly issue. Fixed that a few months ago and now the unit will not drain or spin. It rotates both ways during the wash cycles so I know the motor and the belt are fine.
Any ideas?
#2 Posted : Tuesday, August 3, 2010 4:26:40 PM(UTC)
You may want to check the door lock/switch assembly. The instructions should be in the tech sheet behind the front bottom panel.
Here is the Wiring diagram.
The disassembly instructions are attached to the reply.
- The door lock/switch assembly Part number: AP4455026
File Attachment(s):
Removing the door safety switch.doc (430kb) downloaded 14 time(s).
