I have one of the infamous front loading Kenmores with the spider arm assembly issue. Fixed that a few months ago and now the unit will not drain or spin. It rotates both ways during the wash cycles so I know the motor and the belt are fine. Any ideas?
You may want to check the door lock/switch assembly. The instructions should be in the tech sheet behind the front bottom panel. Here is the Wiring diagram. The disassembly instructions are attached to the reply. - The door lock/switch assembly Part number: AP4455026
