My GE washer is overflowing when set to extra large. All other settings seem to be working properly. Any suggestions to troubleshoot this problem? Thanks in advance for your help. Let me know if you need any additional information.
Pull the small plastic hose off the water level switch and blow in it. If there was some soap residue in the tub, this will clear it. If that fixes the problem, add some vinegar in the tub to clear it out.
