AJShook
#1 Posted : Tuesday, August 3, 2010 9:25:56 AM(UTC)
AJShook
I believe I have a key pad problem, but wanted to check before ordering the console that includes the key pad. The only button that is fully operational on the key pad is the drain/cancel button--it will both start the draining motor and will cancel. The heated dry/lock button, the high temp button, and the normal wash and pots and pans buttons will light when pressed and turn off when I hit cancel or open the washer door. However, none of the other buttons will light when pressed (light wash, delay wash, etc) and, most importantly "start/resume" doesn't work.
I tried to follow the instructions for testing the key pad but got no reading on my analog meter when testing any of the buttons (including the drain/cancel button). I was unable to see any corrosion or breaks in the "P1) connector that I ran the test on and that disappears into the key pad area.
Thanks for whatever advice you can provide me.
#2 Posted : Tuesday, August 3, 2010 11:57:17 AM(UTC)
Your diagnosis sounds right. If you need the correct part number, post the color of the console.
Kenmore Portable Dishwasher (Dishwasher Repair)
by MrsDevereux 1/20/2013 6:01:39 AM(UTC)
