littlechi
#1 Posted : Wednesday, June 18, 2008 6:30:11 AM(UTC)
littlechi
My Maytag washer (MAVT236AWW) very noisy at washing cycle. It OK at spining cycle.
Please help:confused:
#2 Posted : Wednesday, June 18, 2008 7:44:35 PM(UTC)
Lift the washer up from the front, remove the belt and check how freely the pump pulley is moving. Most likely the problem is a bad pump bearing.
- The part number for the pump is AP3873289
littlechi
#3 Posted : Thursday, June 19, 2008 5:41:12 AM(UTC)
littlechi
How freely pump pulley moving? Not that much.
So I have to replace the pump ? Or............
#4 Posted : Thursday, June 19, 2008 10:33:27 AM(UTC)
Faulty pump bearing is one of most common problem with this washer. I believe replacing the pump should solve the problem.
littlechi
#5 Posted : Friday, June 20, 2008 12:49:29 AM(UTC)
littlechi
how can I access to the pump? from bottom or side of the washer?
#6 Posted : Friday, June 20, 2008 10:10:20 AM(UTC)
Remove the rear access panel. If it would not help then remove the front panel.
littlechi
#7 Posted : Monday, June 30, 2008 5:55:44 PM(UTC)
littlechi
I replaced the pump. The washer still noisy.
The sound like metallic sound.
