paul02769
#1 Posted : Friday, July 30, 2010 6:10:20 PM(UTC)
paul02769
My ice maker fills with water but doesn't push the out. When I open the door the optic LED is flashing twice, then pauses, then continues in that pattern. I replaced the ice maker but the same problem exists.
stanlywhite
#2 Posted : Sunday, August 1, 2010 11:33:20 AM(UTC)
stanlywhite
If you remove the bottom vent panel of the refrigerator there are two schematics for the refrigerator. One for the fridge and one for the icemaker. The icemaker has an emitter and a receiver that will tell the icemaker when it is ok to dump ice and add water. The receiver has an LED that blinks different codes. The codes give you an idea where your problem is located. In my case it coded out to be the optics (emitter and receiver). Replacement of the parts involves the removal of three screws on each component and disconnecting a wire harness on each component. Install the new components by following the removal process in reverse.
GOOD LUCK:)
Ice maker not dumping ice in bin (Refrigerator & Freezer Repair)
by Guest 5/31/2021 5:43:12 AM(UTC)
Ice maker not dumping ice (Refrigerator & Freezer Repair)
by bdelk 4/28/2011 5:58:14 AM(UTC)
Kitchenaid Superba ice maker not dumping ice (Refrigerator & Freezer Repair)
by Jamesdog 7/28/2010 10:39:13 AM(UTC)
GE Proile Ice Maker not dumping ice (Refrigerator & Freezer Repair)
by leroychurchill 6/2/2009 8:33:50 AM(UTC)
Belarus joemcsc 9/8/2008 7:08:03 AM(UTC)
