2 Pages<12
abadfish66
#11 Posted : Saturday, June 14, 2008 10:06:22 PM(UTC)
abadfish66
Replacing all 3 will probably fix it, but that's just throwing money away, better to diagnose the problem and fix what is wrong, you can buy a cheap multimeter to help with diagnosis
jl0055
#12 Posted : Monday, June 16, 2008 6:43:40 AM(UTC)
jl0055
OK, I'll buy a multimeter today. I'll be back.
Thank you again.
________
Pattaya Heights Condos
jl0055
#13 Posted : Wednesday, June 18, 2008 12:07:34 PM(UTC)
jl0055
I checked heater and thermostat with multimeter.
heater is dead and thermo is ok.
what should I do next?
________
Sweetayna live
abadfish66
#14 Posted : Wednesday, June 18, 2008 12:14:09 PM(UTC)
abadfish66
Replace your heater, the part # WR51x10053, has now been superceded to a new better heater, WR51x10101. The last heater, was it a genuine GE replacement part?
jl0055
#15 Posted : Wednesday, June 18, 2008 1:33:39 PM(UTC)
jl0055
It was # WR51x10053 and I ordered from this site.
and today I ordered # WR51x10101 from another site which is ************. com. because it was out of stock in this site.
last heater lasted only less than a month.
do I just replace heater?
________
NaughtyNeighbrs live
abadfish66
#16 Posted : Wednesday, June 18, 2008 1:36:40 PM(UTC)
abadfish66
No you don't need to replace the board. Kinda strange the first one failed so soon. Look at the heater and see if it looks like it burned out
jl0055
#17 Posted : Wednesday, June 18, 2008 2:17:51 PM(UTC)
jl0055
the color of the coil inside heater was black when I saw it this afternoon to thaw the frost again. but I don't think It looked like burned out. I'm not sure..
and I have a question. last time when I replaced the heater. there was green wire inside fan box, one end of it was circle shape and connected to the back wall by a screw. and the other end was square shape but I couldn't remember where it had been connected to, so I didn't connect it to anywhere. green wire is ground, right? could it be the problem?
________
The Legend Condo Pattaya
2 Pages<12
