2 Pages12>
jl0055
#1 Posted : Wednesday, June 11, 2008 5:20:53 PM(UTC)
jl0055
Groups ready for retrieval: Registered
1 month ago my refrig was no cooling. so I defrosted all the frost on the coil in the behind the panel (inside freezer) and replaced defrost heater and thermostat. It was ok for about a month. but it happened again. and I defrosted again but 4days after it happened again.
do I need to replace defrost timer? where is it?
someone said it is incorporated in the mother board in the back.
another said it is in the control board in the fresh food section inside the refrig. who is right? what should I do?
and do I have to replace heater and thermostat again when I replace the timer?
Please help me......
________
apartments in Pattaya
abadfish66
#2 Posted : Wednesday, June 11, 2008 10:07:14 PM(UTC)
abadfish66
Neither is right, there is no defrost timer, and the board is located at the back of the cabinet, you need to pull the refer out to get access to the access panel where the board is located. Please provide serial# also, can you give me the GE part# you used to replace the heater, and I will help you with your problem, I am a GE tech for 8 years now
jl0055
#3 Posted : Thursday, June 12, 2008 6:14:45 AM(UTC)
jl0055
Thank You so much.
serial # is MG226141
part # 1 of AP3884317 (WR50X10068) - THERMOSTAT DEF
1 of AP3183868 (WR51X10053) - Heater & bracket asm
________
Web shows
abadfish66
#4 Posted : Thursday, June 12, 2008 7:03:39 AM(UTC)
abadfish66
What is the frost pattern on the evap coils, is the whole thing iced up top to bottom, or is the top half of the evap iced?
jl0055
#5 Posted : Thursday, June 12, 2008 12:16:35 PM(UTC)
jl0055
________
Sunset Boulevard Residence 2 Prathumnak
abadfish66
#6 Posted : Thursday, June 12, 2008 12:25:48 PM(UTC)
abadfish66
Take the wires off the heater and do a continuity check of the heater
jl0055
#7 Posted : Thursday, June 12, 2008 1:11:56 PM(UTC)
jl0055
what do you mean? disconnect the wires from the heater and see if heater works?
________
CreoleBeauty cam
abadfish66
#8 Posted : Thursday, June 12, 2008 1:40:04 PM(UTC)
abadfish66
Do you have a volt meter? If so take the wires off the heater and take an ohm reading of the heater to see if it is good or not
jl0055
#9 Posted : Thursday, June 12, 2008 2:00:35 PM(UTC)
jl0055
No, just voltage tester (to test if a outlet works). not volt meter.
________
Bubbler Pipe
jl0055
#10 Posted : Saturday, June 14, 2008 6:24:50 PM(UTC)
jl0055
if I replace heater and thermostat again
and the board at the back too, then will it be OK?
________
Colorado Dispensary
Guest (8)
2 Pages12>
