Castrok
#1 Posted : Thursday, July 15, 2010 1:42:20 PM(UTC)
Castrok
I have previous post on here dealing with this model not filling. I have model #587.14432200. When I did a parts search, this specific model # is not listed. Would anyone know of a comparable model # that is listed for parts? Also, I am looking for a sump gasket. The one I have is leaking. Also, it won't fill completely. And I have water that is coming out of the drain hose while the unit is running. Any help greatly appreciated.
#2 Posted : Thursday, July 15, 2010 6:08:57 PM(UTC)
Which parts, besides the pump (sump) gasket, are you looking for?
It does not fill properly more likely due to a clogged water inlet valve.
The drain hose should be at least 20" above the ground level.
- The pump gasket Part number: AP2109490
- The water inlet valve Part number: AP4321824
Castrok
#3 Posted : Saturday, July 17, 2010 4:01:57 AM(UTC)
Castrok
Thanks Gene,
I appreciate the info. I will order the parts.
Castrok
#4 Posted : Thursday, July 29, 2010 1:53:23 PM(UTC)
Castrok
I found out the leak was coming from the motor/pump shaft seal area. Is there amy way to just order the seal? I notice a lil' side to side play with the shaft going into the pump housing. Is there a bearing that can be ordered also? I ran the part number of the motor and it only showed the whole assembly (pump and motor assy). Thanks for you help.
#5 Posted : Thursday, July 29, 2010 3:05:40 PM(UTC)
Yes, you can order just the seal assembly, but there are no any bearings.
- The seal assembly Part number: AP3209244
Castrok
#6 Posted : Sunday, August 1, 2010 6:38:59 AM(UTC)
Castrok
Gene,
Thanks again. I appreciate your help. Having problems getting the old shaft seal off. Any helpful hints? I don't want to damage the pump housing or motor. Just about tried everything.
#7 Posted : Sunday, August 1, 2010 7:08:55 PM(UTC)
Very likely the motor shaft is rusted due to the water leak. Try to use WD-40 or something like that. If it would not help and the motor shaft is rusted beyond repair, the whole pump and motor assembly has to be replaced.
- The pump & motor assembly Part number: AP3885612
