I have a Whirlpool oven, everything is working on the stovetop (range) but the oven down below will not work. I think it may be the thermal fuse but I can't seem to locate it. I don't see any diagrams in the owner's manual. Does anyone have any helpful info?:confused:
The model number you posted is incorrect. Verify and repost please.
Sorry the correct number is model #RF302BXGWO. I spoke with a whirlpool representative who informed me that this model does not have a fuse so now I am back to looking at either the thermostat (which to me does not seem logical because I don't have any power in the stove it's not just a degrees issue) or the selector switch. Does anyone know which one it would most likely be? Also does anyone out there know of any reputable used appliance parts sites that would save me a couple of bucks?
Are both the Bake and Broil not working? If it's just the Broil, then there is the thermal fuse for the Broil only. It's shown as #23 on the diagram. Otherwise pull the range out of the wall. Remove the rear panel and check all wires between the heating elements and the controls. Check the selector switch and the thermostat for continuity according to the Wiring diagram. Here are the breakdown diagrams and Replacement parts for WHIRLPOOL RF302BXGW0 | AppliancePartsPros.comGene.
