tators
#1 Posted : Wednesday, July 28, 2010 12:07:22 PM(UTC)
tators
Hello, I Have Replaced The Defrost Heater And Thermostat Yesterday (per A Qualified Tech, After Trouble Shooting Problem) And The Fridge Is Still Not As Cold As It Should Be.
The Defrost Timer Is Working Properlly. Is There Something Else That Needs To Be Done?
Joe / APP Team
#2 Posted : Wednesday, July 28, 2010 12:37:58 PM(UTC)
Joe / APP Team
Did you disturb the temperature control or the temperature bulb in the control console, when you were doing the repair ?
Check and make sure they are reset to the original position(s).
With this design of refrigerator, if a ice build up,due to a defrost problem is heavy enough, you can get a ice build up or debris in the damper assembly which will restrict the air flow to the fresh food compartment,and cause warmer temperatures.
Thats where I would start, in this particular case
tators
#3 Posted : Wednesday, July 28, 2010 12:53:02 PM(UTC)
tators
I HAVE THE TEMP CONTROLS AT THE ORIGINAL (OR WHERE THEY WERE WHEN PROBLEM STARTED) SETTINGS.
THE DAMPER ASSEMBLLY IS LOCATED IN THE FRIDGE COMPARTMENT, CORRECT?
OR SHOULD I GIVE THIS MORE TIME TO COOL DOWN? ALSO THE COILS AND FREEZER THAWD OUT COMPLETELLY AS I WAS DOING REPAIRS
Joe / APP Team
#4 Posted : Wednesday, July 28, 2010 1:42:03 PM(UTC)
Joe / APP Team
Your damper assembly and you teperature control / temp bulb are located in the control panel console(mounted to the ceiling of the fresh food compartment).
If the unit has been running at least 20 to 24 hours after the repair, I would expect the temperatures to be proper and in range by then.
You may have to remove the console and check for water / ice in the damper assembly and insure the end of the temperature probe is in the proper position(in the air flow from the freezer compartment).
tators
#5 Posted : Wednesday, July 28, 2010 1:46:47 PM(UTC)
tators
Thank You, I Will Check That
Joe / APP Team
#6 Posted : Thursday, July 29, 2010 5:15:52 AM(UTC)
Joe / APP Team
I suspect, that's were you'll find the problem.
I've encounterred it myself several times.
Good Luck,
Samsung Fridge warm, Freezer OK (Refrigerator & Freezer Repair)
by Ydnar 12/16/2011 2:07:59 PM(UTC)
Fridge warm, Freezer ok (Refrigerator & Freezer Repair)
by TommyN71 12/11/2011 2:53:43 PM(UTC)
