jfm722
#1 Posted : Tuesday, June 17, 2008 1:44:12 PM(UTC)
jfm722
I was hoping someone could help me determine which part needs to be replace in our GE oven. The broiler works but the oven will not heat up. It worked the night before and late that evening we had a power outage for several hours due to bad storms. Could that have caused the problem? Thanks for any help.
abadfish66
#2 Posted : Tuesday, June 17, 2008 1:49:45 PM(UTC)
abadfish66
Does everything else work, just not bake, if that's the case, your bake glowbar may be bad. When you program it to bake, do you get a glow at all?
jfm722
#3 Posted : Tuesday, June 17, 2008 1:52:16 PM(UTC)
jfm722
Everything else works, it's just seems to be the oven that won't heat. I also don't see any type of glow. Thanks for any help. John
abadfish66
#4 Posted : Tuesday, June 17, 2008 1:59:25 PM(UTC)
abadfish66
Thought yours was an electronic model, hang tight
abadfish66
#5 Posted : Tuesday, June 17, 2008 2:02:01 PM(UTC)
abadfish66
Take an ohm reading of your glowbar, should be between 50-150ohms, if not within this range, your glowbar needs to be replaced
abadfish66
#6 Posted : Tuesday, June 17, 2008 2:03:28 PM(UTC)
abadfish66
Here's a diagram of your range Model JGBP85CEB2CC
jfm722
#7 Posted : Tuesday, June 24, 2008 9:30:33 AM(UTC)
jfm722
Abadfish66, Thanks for the information. I was able to replace the bake glowbar and now all is working. Thanks again, Jen
abadfish66
#8 Posted : Tuesday, June 24, 2008 9:39:28 AM(UTC)
abadfish66
Glad you fixed it
Guest (6)
