springerider
#1 Posted : Tuesday, July 27, 2010 3:30:06 PM(UTC)
springerider
GE Side-by-side water dispenser drips constantly after each use. I disassembled and cleaned the parts in the door; cannot find anything obvious.
I ordered a new water valve AP2071735 (WR57X10023) with the suspicion that it is not closing completely. If this doesn't solve the problem is the next likely culprit the circuit board for the dispenser?
wayne7646
#2 Posted : Friday, April 1, 2011 2:45:21 AM(UTC)
wayne7646
I have the same problem. Have not tried replacing the valve yet. My GE fridge is about 18 mos. old. Let me know if replacing the valve works. By the way when I lock the system, the valve does not leak. this makes me suspicious that it is more than just the valve.
Water dispenser leaks when ice maker fills (Refrigerator & Freezer Repair)
by Steenbockj 2/21/2013 10:06:36 AM(UTC)
Front filtered water dispenser leaks (Refrigerator & Freezer Repair)
by trogers2000 10/22/2012 3:47:38 AM(UTC)
refrigerator water dispenser leaks (Refrigerator & Freezer Repair)
by fridgedrip 10/19/2011 9:52:14 AM(UTC)
water dispenser leaks (yes I replaced the water inlet valve, filter, and installed s) (Refrigerator & Freezer Repair)
by david465 3/10/2010 5:27:17 PM(UTC)
Icemaker Water Dispenser leaks onto floor (Refrigerator & Freezer Repair)
by Matadormac 8/17/2009 2:21:53 AM(UTC)
The water dispenser leaks continually, had to cut the water off to stop it (Refrigerator & Freezer Repair)
by Willie Jones 7/12/2009 4:32:26 PM(UTC)
Water Dispenser Leaks (Refrigerator & Freezer Repair)
by b1rdman75 5/15/2009 4:45:30 PM(UTC)
