hillbilly
#1 Posted : 15 years ago
hillbilly
dishwasher starts then display blinks and washer shuts down then tries to start again .ran self test mode and turbidity sensor fails then ran it again and motor low current faults. think motor is going south, need help.:confused:
Joe / APP Team
#2 Posted : 15 years ago
Joe / APP Team
You may not have a component failure at all.
This particular style unit is susceptable to false information,inputs to the control board.
The turbidity sensor failure could be due to sudsing, low water level,or deposits accumulated in pump and spray arms(possibly hard water deposits detergent residue.( proper water level :heater element should be partially submerged after unit fills and runs at least five minutes).
I would reccomend, you partially dismantle the pump assembly(at least to the water pressure dome and clean them with hot water and white vinegar, and the pump body as well,
Your low motor current fail code could be due to the same reasons: sudsing, low water level, debris and deposits in the pump assembly or spray arms, as well as a power supply problem, loose connections at the sensor and motor ,voltage fluctuations or voltage under a load(when motor starts).
I would reccomend you follow the cleaning procedure described above.
Check your water temperature (130 to 140 degrees) at start of the cycle(fill) in the tub.
You may want to change detergents (prefer powder detergent with no additives,myself) and reduce the rinse agent dispenser to the lowest setting to help control sudsing.
I'm pretty sure these procedures will solve your problems,
Please contact us if your problem persists
hillbilly
#3 Posted : 15 years ago
hillbilly
Joe M thanks for the reply.I took the dishwasher all the way down to the pump and cleaned it out with air compressor.When I ran just a rinse and hold cycle it washed and drained. It skips the sense clean sensor in that mode.The turbidity sensor is no longer available they tell me.can I bypass the sensor.
Joe / APP Team
#4 Posted : 15 years ago
Joe / APP Team
I will double check with some of my sources, and let you know.
If I remember correctly, you can leave the sensor harness disconnected from the sensor assembly, but let me double check
Joe M.
Another Jenn Air Problem with burner control (Oven Repair (including Ranges and Cooktops))
by klingenfelter 16 years ago
