SirTreek23
#1 Posted : Monday, July 26, 2010 10:57:34 AM(UTC)
SirTreek23
I have been researching to replace the agitator dogs in my Kenmore 90 Plus series washer, and everything that I read says that when I take off the agitator cap, there is a bolt there to be removed to take off the whole assembly. My problem however, is that there is no bolt there. I can see the top of what looks like just a metal rod, but no bolt in sight. Is there some other way that I am just not finding to remove the assembly? :confused:
Thanks.
#2 Posted : Monday, July 26, 2010 2:09:57 PM(UTC)
What is the complete model number of the washer?
SirTreek23
#3 Posted : Monday, July 26, 2010 3:34:28 PM(UTC)
SirTreek23
110.28932790
SirTreek23
#4 Posted : Monday, July 26, 2010 4:23:42 PM(UTC)
SirTreek23
Found out the problem. Apparently some models have a plastic piece there with a square opening in it. I had no clue that IT was the part you need to unscrew. My friend found a ratchet extender with a square end and it fit perfectly and popped right out!
#5 Posted : Monday, July 26, 2010 5:11:24 PM(UTC)
I'm glad you were able to figure out how to handle it. Thank you for the feed back.
bigO
#6 Posted : Monday, February 21, 2011 4:23:56 PM(UTC)
bigO
Hello this is exactly my problem too, but where can i buy this square tool because my ratchets are too small and dont fit. The square opening is bigger in size. please help. thanks!
#7 Posted : Monday, February 21, 2011 7:59:59 PM(UTC)
The tool you are looking for is a 1/2" socket wrench driver.
My agitator bolt will not come out (Washer Repair)
by Guest 8/14/2022 4:47:19 PM(UTC)
Rusted agitator bolt (Washer Repair)
by Betsy2 8/1/2018 8:02:15 AM(UTC)
Whirlpool top load washer, wtw4800bq0, agitator bolt loose, and bottom moves (Washer Repair)
by Girliemom21 7/18/2017 5:57:17 AM(UTC)
Agitator Bolt (Washer Repair)
by dwm0304 11/15/2015 12:13:37 AM(UTC)
Agitator bolt comes loose (Washer Repair)
by squibel1965 1/29/2015 5:07:34 AM(UTC)
Agitator Bolt & Washer Question (with Pictures) (Washer Repair)
by mtnbiker3000 10/18/2012 2:48:10 PM(UTC)
stripped agitator bolt on transmission (Washer Repair)
by late arrival 7/24/2012 2:38:01 PM(UTC)
Removing the upper agitator bolt (Washer Repair)
by pcntexas 12/10/2007 11:31:41 AM(UTC)
