4 Pages123>»
rod767
#1 Posted : Friday, June 13, 2008 6:38:29 AM(UTC)
rod767
washer showed error code F-50. trouble shooting said to replace main control board, so I ordered a new board with you.
My old board p/n is W10104820, the new board from you is p/n W10188476 Rev.A
when I plug in the new board, and turn on power, I get an error code F-2 now. That code means control board user interface error. What should I do?
Your site shows the two boards as the same, and visually they do look exactly the same. Is there some sort of reset to get the interface to recognize the new board?
Thank for any help.
#2 Posted : Sunday, June 15, 2008 3:03:10 PM(UTC)
Hi Rod,
Did you perform all tests as recommended in the tech sheets to diagnose the cause of the "F-50" fault code? If you did - post the results. If you did not - how did you know that the control board is bad?
rod767
#3 Posted : Sunday, June 15, 2008 4:24:39 PM(UTC)
rod767
Thanks for ansewering Gene, yes I did, and the final outcome was to replace the control board.
#4 Posted : Sunday, June 15, 2008 9:01:54 PM(UTC)
Originally Posted by: rod767 Go to Quoted Post
...My old board p/n is W10104820, the new board from you is p/n W10188476...
Did you get this part number (W10104820) form the old part or somewhere else?
rod767
#5 Posted : Monday, June 16, 2008 3:21:23 AM(UTC)
rod767
yes, I got the part num right off of the board.
#6 Posted : Monday, June 16, 2008 1:16:15 PM(UTC)
Rod,
Looks like Whirlpool provided wrong part number cross over for this control board. According to Sears data base, per the model number you posted, the right part number for this control board is W10201186 which is Appliance Parts Pros item number AP4355605.
You have to contact Adam from Appliance Parts Pros customer service and he will help you to exchange this part.
rod767
#7 Posted : Monday, June 16, 2008 3:34:27 PM(UTC)
rod767
Thanks Gene, that's what I thought. I've started a return process, but they haven't emailed me back yet with the RMA. I'll try directly with Adam. Keep up the great work. You're priceless to this forum!!!:D:D:D:D:D
raf215
#8 Posted : Monday, October 6, 2008 2:22:58 PM(UTC)
raf215
I've got a slightly different problem with my Kenmore washer. The model is 110.27082603. Over the weekend it started behaving very different. Tried doing some laundry over weekend and needless to say it didn't run very well. I selected Towels/Sheets and once it started it kept toggling back and forth between 45 minutes/no spin to 58 minutes/2nd spin. I stopped the machine.
Early this morning, washer was beeping - got up and display was flashing F2 - user interface - is it the control board (same # as what's already been mentioned in thread) or user interface board? Have done some calling around and the consenses is control board.
Thanks in Advance,
Ray
#9 Posted : Monday, October 6, 2008 5:35:05 PM(UTC)
Hi Ray,
Control board and user interface board are both an electronic parts and your washer has both of them.
- The part number for the user interface board is AP3919482
raf215
#10 Posted : Tuesday, October 7, 2008 6:19:20 AM(UTC)
raf215
Hi Gene,
Thanks for the quick reply. This morning I tried to run another Towel/Sheet wash. Initial display was 45 minutes/no 2nd spin. I did not press any buttons on the front and the display went to 60 minutes with a 2nd spin then a minute or 2 later it went back to 45 minutes/no spin. It sounds to me like it's the control board since I didn't touch any buttons.
I've got Sears scheduled to come out tomorrow but I am a DIYer so if you have the controller, I'd rather order the part and cancel the appt since I'd be paying the tech for something that I already know what's wrong. UserPostedImage
BTW, would you have a tech sheets for this model washer?
Thanks in Advance,
Ray
Kenmore Oasis Elite heat issue (Dryer Repair)
by dkessinger 5/5/2015 12:43:24 PM(UTC)
Kenmore Oasis Washer F1 code (Washer Repair)
by sofedup 1/2/2012 8:18:51 AM(UTC)
Kenmore Oasis--loud spin cycle--water pressure? (Washer Repair)
by love2box 12/23/2011 12:07:52 PM(UTC)
Kenmore Oasis noisy when filling (Washer Repair)
by Reedster 12/6/2011 1:40:53 PM(UTC)
Kenmore Oasis Washer F68 (Washer Repair)
by chikag 10/5/2011 4:16:46 PM(UTC)
kenmore oasis washer (Washer Repair)
by craymomtls@aol.com 8/28/2011 4:58:34 AM(UTC)
Kenmore Oasis Washer Error Code F51 (Washer Repair)
by g5d9s 8/17/2011 9:23:23 AM(UTC)
Kenmore Oasis Elite HE (Washer Repair)
by JTA 7/27/2011 6:54:48 AM(UTC)
kenmore oasis cant find model or serial # (Washer Repair)
by jj20375 6/29/2011 1:51:17 PM(UTC)
Kenmore Oasis Turns on by itself/beeps/arbitrarily changes settings (Washer Repair)
by kingirp 2/15/2011 8:37:44 AM(UTC)
kenmore oasis dying (Washer Repair)
by ferg431 1/30/2010 5:28:42 PM(UTC)
Kenmore Oasis Washer (Washer Repair)
by dwalker4 1/14/2010 2:45:17 PM(UTC)
Kenmore Oasis 27032600 Power Problem (Washer Repair)
by nylabor 10/31/2009 1:58:01 PM(UTC)
kenmore oasis lid does not lock (Washer Repair)
by wgb123 9/30/2009 7:24:22 AM(UTC)
kenmore oasis he fault code F50 (Washer Repair)
by end of the road gang 9/13/2009 7:51:11 AM(UTC)
4 Pages123>»
