Went turn on the stove and slected bake. Nothng happened. all other function work including broil,cleaning, timmers, ect. What could be worng?
Thanks Gene, The problem is that when I touch bake on the key pad nothing happens. No beep nothing. If I push say broil it will beep and and flash Hi/LO, as well as all the other functions.Two monts ago I replaced the igniter, when that went bad I pushed the bake on the key-pad it beeped and the temp display showed 100 degrees but the it never turned on. Since I replaced it it has been working fine, till now. I have gone as far as replacing the control unit with no luck. I was thinking the only thing left is the key-pad (which is expensive) any thoughts? thanks again
Hi Steve, You are right, the key panel has to be replaced to solve this problem and it is expensive. - The part number for the key panel is AP2035214 Gene.
Originally Posted by: Gene  Hi Steve, You are right, the key panel has to be replaced to solve this problem and it is expensive. - The part number for the key panel is AP2035214 Gene. Gere, Replaced the key panel and we are cooking (baking) with gas. Thanks much for your time and advice. ~Steve B.
Hi Steve,
I'm glad you were able to fix it.
